Retired_Member
Dec 01, 2015Can't shutdown Ready NAS rn104 with 6.1.4 RC3
Hello I have a VERY irritating problem. Everything time I turn off my NAS unit it just starts up again. After 3-4 sec. I have disk sleep turned off and auto standby schedule off. Anyone?????? Now I...
- Retired_MemberDec 04, 2015
I found the sollution myself!!!!
It was the addon VPN 1.5.0 that caused the change of MTU every system shutdown. As soon as i uninstalled it everything worked flawlessy again!!!!!
Dec 02, 2015
The issue identified by the support case will only occur if you have actively changed the MTU from 1500 to 9000. If you haven't changed the MTU, then your case is different to mine. Go to "Network" and have a look at your MTU. If it's 1500 and your box doesn't stay shutdown, it is a new issue. If it is above 1500, change it back to 1500 by clicking on the cog and reboot and see if a shutdown stays shutdown.
The below is a screenshot of my working legacy Ultra6 with jumbo frames (for illustration purposes), which works fine. My RN102 doesn't work with WoL and Jumbo frames and has an MTU of 1500.
Retired_Member
Dec 03, 2015Hello again
Mine was set to 1985.....instead of 1500.
Now everythings working with system shutdown again. What am I loosing here. Any performance loss from going from 1985 to 1500????
