gonzonia
Oct 05, 2013Aspirant
Can't stream from DLNA without a reboot
I've been using the DLNA successfully for a while now with my ReadyNAS NVX Pioneer. I'm not sure if my problems started after the latest radiator update or before that. When I attempt to stream a vide...
gonzonia
Oct 08, 2013Aspirant
I did a reboot, but I noticed this in the dlna debug logs first. I'll check the file's open later tonight. The limit is 1024.
That IP is my Yamaha receiver which should be idle. I don't know why it's doing anything.
There are other requests form it as well.
[2013/10/08 08:30:44] upnphttp.c:688: debug: ProcessHTTPSubscribe /evt/X_MS_MediaReceiverRegistrar
[2013/10/08 08:30:44] upnphttp.c:690: debug: Callback 'http://192.168.99.14:49153/' Timeout=3600
[2013/10/08 08:30:44] upnphttp.c:691: debug: SID ''
[2013/10/08 08:30:44] upnpevents.c:152: debug: addSubscriber(/evt/X_MS_MediaReceiverRegistrar, http://192.168.99.14:49153/, 3600)
[2013/10/08 08:30:44] getifaddr.c:255: error: getifaddrs(): Too many open files
[2013/10/08 08:30:44] uuid.c:157: info: Could not find MAC. Use bootid's nodeID.
[2013/10/08 08:30:44] uuid.c:160: info: bootid node not successfully read.
[2013/10/08 08:30:44] upnpevents.c:234: error: upnp_event_create_notify: socket(): Too many open files
[2013/10/08 08:30:44] upnphttp.c:705: debug: generated sid=uuid:738e35c9-3015-11e3-828e-e4e6653711e5
[2013/10/08 08:30:44] upnphttp.c:1157: debug: HTTP RESPONSE: HTTP/1.1 200 OK
[2013/10/08 08:30:44] minidlna.c:1301: debug: HTTP connection from 192.168.99.14:2567
[2013/10/08 08:30:44] upnphttp.c:833: debug: HTTP REQUEST: POST /ctl/X_MS_MediaReceiverRegistrar HTTP/1.1
[2013/10/08 08:30:53] minissdp.c:674: info: SSDP M-SEARCH from 192.168.99.14:6563 ST: urn:schemas-upnp-org:device:MediaServer:1, MX: 2, MAN: "ssdp:discover"
[2013/10/08 08:30:53] minissdp.c:674: info: SSDP M-SEARCH from 192.168.99.14:6563 ST: urn:schemas-upnp-org:service:ContentDirectory:1, MX: 2, MAN: "ssdp:discover"
[2013/10/08 08:30:53] minidlna.c:1301: debug: HTTP connection from 192.168.99.14:2568
[2013/10/08 08:30:53] upnphttp.c:833: debug: HTTP REQUEST: SUBSCRIBE /evt/X_MS_MediaReceiverRegistrar HTTP/1.1
