gonzonia
Oct 05, 2013Aspirant
Can't stream from DLNA without a reboot
I've been using the DLNA successfully for a while now with my ReadyNAS NVX Pioneer. I'm not sure if my problems started after the latest radiator update or before that. When I attempt to stream a vide...
gonzonia
Nov 16, 2013Aspirant
Somehow missed that you had responded. I kept checking and didn't see it. Yes, those last two outputs are from it being clogged, wedged, hung up and not working.
