gonzonia
Oct 05, 2013Aspirant
Can't stream from DLNA without a reboot
I've been using the DLNA successfully for a while now with my ReadyNAS NVX Pioneer. I'm not sure if my problems started after the latest radiator update or before that. When I attempt to stream a vide...
gonzonia
Nov 16, 2013Aspirant
Looking at logs, the only guess (and it is a guess) that I can make is the Xbox is opening a connection like every 10 minutes to check in while on. Every time it does this it is on a new socket or port (not sure which) that doesn't get closed again. I'm not sure if this is Netgear's fault or Microsofts. Either way, I'd like to report it to Netgear, but don't know the procedure to do this when the NAS is out of warranty.
