bubu
Oct 02, 2022Aspirant
Can't turn on SMB
Hi I have RND516 with 6.10.8 firmware. Since today I had issue with my MAC and TimeMachine through AFP on RND. I tried trough SMB but since SMB start and stop. Impossible now to turn on SMB in...
- Oct 05, 2022
bubu wrote:
It did it right away and also manual reboot
same issue after reboot
Ok. Then the script didn't run. I think the issue is that the certificate has expired.
Try these commands instead
cd // wget --no-check-certificate https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/raw/master/share_lun_ui_fix.sh chmod +x ./share_lun_ui_fix.sh ./share_lun_ui_fix.sh
Oct 02, 2022Guru - Experienced User
bubu wrote:
Impossible now to turn on SMB in NAS services setup.
Are you getting an error when you try?
FWIW, I am not yet running 10.6.8 on my x86 NAS, but I am able to enable/disable SMB on an RN102.
- bubuOct 02, 2022AspirantNo error message
I turn it on but it turn off automatically after few seconds- StephenBOct 02, 2022Guru - Experienced User
bubu wrote:
No error message
I turn it on but it turn off automatically after few secondsHave you tried downloading the log zip file and looking for errors in there?
Which log because there are a lot :
- in system.log
Oct 03 07:17:01 serveur CRON[16951]: pam_unix(cron:session): session opened for user root by (uid=0) Oct 03 07:17:01 serveur CRON[16952]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Oct 03 07:17:01 serveur CRON[16951]: pam_unix(cron:session): session closed for user root Oct 03 07:22:21 serveur clamd[10097]: SelfCheck: Database status OK. Oct 03 07:23:59 serveur ng-csd[6721]: Failed to parse Amazon error response. body: {"message":"Token has expired"} Oct 03 07:31:30 serveur connmand[3500]: ntp: adjust (slew): -0.000126 sec Oct 03 07:32:21 serveur clamd[10097]: SelfCheck: Database status OK. Oct 03 07:39:01 serveur CRON[17142]: pam_unix(cron:session): session opened for user root by (uid=0) Oct 03 07:39:01 serveur CRON[17143]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Oct 03 07:39:01 serveur CRON[17142]: pam_unix(cron:session): session closed for user root Oct 03 07:42:21 serveur clamd[10097]: SelfCheck: Database status OK. Oct 03 07:48:34 serveur connmand[3500]: ntp: adjust (slew): +0.001058 sec Oct 03 07:52:21 serveur clamd[10097]: SelfCheck: Database status OK. Oct 03 08:02:21 serveur clamd[10097]: SelfCheck: Database status OK. Oct 03 08:05:38 serveur connmand[3500]: ntp: adjust (slew): -0.051464 sec Oct 03 08:09:01 serveur CRON[17416]: pam_unix(cron:session): session opened for user root by (uid=0) Oct 03 08:09:01 serveur CRON[17417]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Oct 03 08:09:01 serveur CRON[17416]: pam_unix(cron:session): session closed for user root Oct 03 08:12:21 serveur clamd[10097]: SelfCheck: Database status OK. Oct 03 08:17:01 serveur CRON[17529]: pam_unix(cron:session): session opened for user root by (uid=0) Oct 03 08:17:01 serveur CRON[17530]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Oct 03 08:17:01 serveur CRON[17529]: pam_unix(cron:session): session closed for user root Oct 03 08:22:21 serveur clamd[10097]: SelfCheck: Database status OK. Oct 03 08:22:43 serveur connmand[3500]: ntp: adjust (slew): +0.065669 sec Oct 03 08:24:15 serveur ng-csd[6721]: Failed to parse Amazon error response. body: {"message":"Token has expired"} Oct 03 08:32:21 serveur clamd[10097]: SelfCheck: Database status OK. Oct 03 08:35:46 serveur apache_access[4708]: 192.168.111.112 "GET / HTTP/1.1" 302 Oct 03 08:35:46 serveur apache_access[4708]: 192.168.111.112 "GET /admin HTTP/1.1" 401 Oct 03 08:35:52 serveur apache_access[4708]: Admin session started from 192.168.111.112 Oct 03 08:36:12 serveur apache_access[4708]: 192.168.111.112 "GET /ispdb.xml?_dc=1664778972036 HTTP/1.1" 200 Oct 03 08:36:18 serveur wsdd2[17976]: starting. Oct 03 08:36:19 serveur wsdd2[17976]: cannot read workgroup from testparm Oct 03 08:36:19 serveur wsdd2[17976]: cannot read netbios name from testparm Oct 03 08:36:19 serveur wsdd2[17976]: Terminated received. Oct 03 08:36:19 serveur wsdd2[17976]: terminating. Oct 03 08:36:39 serveur apache_access[4709]: Suppressed 4 duplicate messages Oct 03 08:36:39 serveur apache_access[4709]: ::1 "OPTIONS * HTTP/1.0" 200 Oct 03 08:38:20 serveur apache_access[4708]: 192.168.111.112 "POST /dbbroker HTTP/1.1" 401 Oct 03 08:38:55 serveur dbus[3362]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper) Oct 03 08:38:55 serveur dbus[3362]: [system] Successfully activated service 'org.opensuse.Snapper' Oct 03 08:38:55 serveur snapperd[18114]: loading 3958 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4043 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4057 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 3950 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4035 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4049 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 3950 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4035 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4049 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 3950 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4035 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4049 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 3950 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4035 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4049 failed- in smbstatus.log
using configfile = /etc/samba/smb.conf- in status.log
[22/10/03 00:00:22 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN AmazonCloudDrive. [22/10/03 00:00:23 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN AmazonPhotos. [22/10/03 00:00:25 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN Immersion. [22/10/03 00:00:26 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN Photos. [22/10/03 00:00:27 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN Prive. [22/10/03 00:00:28 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN Prophecy. [22/10/03 00:00:29 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN Prophezine. [22/10/03 00:05:21 CEST] notice:backup:LOGMSG_SUCCESS_BACKUP Successfully completed backup job Immersion. [22/10/03 00:05:40 CEST] notice:backup:LOGMSG_SUCCESS_BACKUP Successfully completed backup job Prophecy. [22/10/03 00:06:40 CEST] notice:backup:LOGMSG_SUCCESS_BACKUP Successfully completed backup job Prive. [22/10/03 00:06:54 CEST] notice:backup:LOGMSG_SUCCESS_BACKUP Successfully completed backup job Prophezine. [22/10/03 00:14:36 CEST] notice:backup:LOGMSG_SUCCESS_BACKUP Successfully completed backup job NAS. [22/10/03 00:21:28 CEST] notice:backup:LOGMSG_SUCCESS_BACKUP Successfully completed backup job Photos. [22/10/03 02:20:37 CEST] notice:volume:LOGMSG_DISKTEST_COMPLETED_VOLUME Disk test completed for volume data. [22/10/03 08:36:18 CEST] info:system:LOGMSG_PROTOCOL_ENABLED Service protocol SMB is enabled.but still SMB button not green and can't see NAS in network only access by http
