bubu
Oct 02, 2022Aspirant
Can't turn on SMB
Hi I have RND516 with 6.10.8 firmware. Since today I had issue with my MAC and TimeMachine through AFP on RND. I tried trough SMB but since SMB start and stop. Impossible now to turn on SMB in...
- Oct 05, 2022
bubu wrote:
It did it right away and also manual reboot
same issue after reboot
Ok. Then the script didn't run. I think the issue is that the certificate has expired.
Try these commands instead
cd // wget --no-check-certificate https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/raw/master/share_lun_ui_fix.sh chmod +x ./share_lun_ui_fix.sh ./share_lun_ui_fix.sh
bubu
No error message
I turn it on but it turn off automatically after few seconds
Oct 02, 2022Guru - Experienced User
bubu wrote:
No error message
Have you tried downloading the log zip file and looking for errors in there?
- bubuOct 02, 2022Aspirant
Which log because there are a lot :
- in system.log
Oct 03 07:17:01 serveur CRON[16951]: pam_unix(cron:session): session opened for user root by (uid=0) Oct 03 07:17:01 serveur CRON[16952]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Oct 03 07:17:01 serveur CRON[16951]: pam_unix(cron:session): session closed for user root Oct 03 07:22:21 serveur clamd[10097]: SelfCheck: Database status OK. Oct 03 07:23:59 serveur ng-csd[6721]: Failed to parse Amazon error response. body: {"message":"Token has expired"} Oct 03 07:31:30 serveur connmand[3500]: ntp: adjust (slew): -0.000126 sec Oct 03 07:32:21 serveur clamd[10097]: SelfCheck: Database status OK. Oct 03 07:39:01 serveur CRON[17142]: pam_unix(cron:session): session opened for user root by (uid=0) Oct 03 07:39:01 serveur CRON[17143]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Oct 03 07:39:01 serveur CRON[17142]: pam_unix(cron:session): session closed for user root Oct 03 07:42:21 serveur clamd[10097]: SelfCheck: Database status OK. Oct 03 07:48:34 serveur connmand[3500]: ntp: adjust (slew): +0.001058 sec Oct 03 07:52:21 serveur clamd[10097]: SelfCheck: Database status OK. Oct 03 08:02:21 serveur clamd[10097]: SelfCheck: Database status OK. Oct 03 08:05:38 serveur connmand[3500]: ntp: adjust (slew): -0.051464 sec Oct 03 08:09:01 serveur CRON[17416]: pam_unix(cron:session): session opened for user root by (uid=0) Oct 03 08:09:01 serveur CRON[17417]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Oct 03 08:09:01 serveur CRON[17416]: pam_unix(cron:session): session closed for user root Oct 03 08:12:21 serveur clamd[10097]: SelfCheck: Database status OK. Oct 03 08:17:01 serveur CRON[17529]: pam_unix(cron:session): session opened for user root by (uid=0) Oct 03 08:17:01 serveur CRON[17530]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Oct 03 08:17:01 serveur CRON[17529]: pam_unix(cron:session): session closed for user root Oct 03 08:22:21 serveur clamd[10097]: SelfCheck: Database status OK. Oct 03 08:22:43 serveur connmand[3500]: ntp: adjust (slew): +0.065669 sec Oct 03 08:24:15 serveur ng-csd[6721]: Failed to parse Amazon error response. body: {"message":"Token has expired"} Oct 03 08:32:21 serveur clamd[10097]: SelfCheck: Database status OK. Oct 03 08:35:46 serveur apache_access[4708]: 192.168.111.112 "GET / HTTP/1.1" 302 Oct 03 08:35:46 serveur apache_access[4708]: 192.168.111.112 "GET /admin HTTP/1.1" 401 Oct 03 08:35:52 serveur apache_access[4708]: Admin session started from 192.168.111.112 Oct 03 08:36:12 serveur apache_access[4708]: 192.168.111.112 "GET /ispdb.xml?_dc=1664778972036 HTTP/1.1" 200 Oct 03 08:36:18 serveur wsdd2[17976]: starting. Oct 03 08:36:19 serveur wsdd2[17976]: cannot read workgroup from testparm Oct 03 08:36:19 serveur wsdd2[17976]: cannot read netbios name from testparm Oct 03 08:36:19 serveur wsdd2[17976]: Terminated received. Oct 03 08:36:19 serveur wsdd2[17976]: terminating. Oct 03 08:36:39 serveur apache_access[4709]: Suppressed 4 duplicate messages Oct 03 08:36:39 serveur apache_access[4709]: ::1 "OPTIONS * HTTP/1.0" 200 Oct 03 08:38:20 serveur apache_access[4708]: 192.168.111.112 "POST /dbbroker HTTP/1.1" 401 Oct 03 08:38:55 serveur dbus[3362]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper) Oct 03 08:38:55 serveur dbus[3362]: [system] Successfully activated service 'org.opensuse.Snapper' Oct 03 08:38:55 serveur snapperd[18114]: loading 3958 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4043 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4057 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 3950 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4035 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4049 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 3950 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4035 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4049 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 3950 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4035 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4049 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 3950 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4035 failed Oct 03 08:38:55 serveur snapperd[18114]: loading 4049 failed- in smbstatus.log
using configfile = /etc/samba/smb.conf- in status.log
[22/10/03 00:00:22 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN AmazonCloudDrive. [22/10/03 00:00:23 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN AmazonPhotos. [22/10/03 00:00:25 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN Immersion. [22/10/03 00:00:26 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN Photos. [22/10/03 00:00:27 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN Prive. [22/10/03 00:00:28 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN Prophecy. [22/10/03 00:00:29 CEST] info:snapshot:LOGMSG_SNAPSHOT_CREATE_INFO Snapshot c_1664748020 was successfully created for share or LUN Prophezine. [22/10/03 00:05:21 CEST] notice:backup:LOGMSG_SUCCESS_BACKUP Successfully completed backup job Immersion. [22/10/03 00:05:40 CEST] notice:backup:LOGMSG_SUCCESS_BACKUP Successfully completed backup job Prophecy. [22/10/03 00:06:40 CEST] notice:backup:LOGMSG_SUCCESS_BACKUP Successfully completed backup job Prive. [22/10/03 00:06:54 CEST] notice:backup:LOGMSG_SUCCESS_BACKUP Successfully completed backup job Prophezine. [22/10/03 00:14:36 CEST] notice:backup:LOGMSG_SUCCESS_BACKUP Successfully completed backup job NAS. [22/10/03 00:21:28 CEST] notice:backup:LOGMSG_SUCCESS_BACKUP Successfully completed backup job Photos. [22/10/03 02:20:37 CEST] notice:volume:LOGMSG_DISKTEST_COMPLETED_VOLUME Disk test completed for volume data. [22/10/03 08:36:18 CEST] info:system:LOGMSG_PROTOCOL_ENABLED Service protocol SMB is enabled.but still SMB button not green and can't see NAS in network only access by http
- StephenBOct 03, 2022Guru - Experienced User
Normally I'd look in kernel.log, system.log, and systemd-journal.log, and see if there are any SMB related errors or crashes. dmesg.log also sometimes has useful information.
You are showing some other errors (likely unrelated) with snapshots that might need to be sorted out at some point.
Did this problem happen as soon as you upgraded to 6.10.8?
Have you tried an OS reinstall?
- bubuOct 03, 2022Aspirant
How can reinstall it ?
Any issue for my data? because I can't loose them.
