bubu
Oct 02, 2022Aspirant
Can't turn on SMB
Hi I have RND516 with 6.10.8 firmware. Since today I had issue with my MAC and TimeMachine through AFP on RND. I tried trough SMB but since SMB start and stop. Impossible now to turn on SMB in...
- Oct 05, 2022
bubu wrote:
It did it right away and also manual reboot
same issue after reboot
Ok. Then the script didn't run. I think the issue is that the certificate has expired.
Try these commands instead
cd // wget --no-check-certificate https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/raw/master/share_lun_ui_fix.sh chmod +x ./share_lun_ui_fix.sh ./share_lun_ui_fix.sh
bubu
Oct 05, 2022Aspirant
Oct 05, 2022Guru - Experienced User
cd //
- Apr 19, 2022Retired_Member
