emerson8
Jan 06, 2012Aspirant
can't upgrade or reboot ?
Hi,, been using a Readynas Pro 6 with fw; 4.2.20-T19 for a while, thought I'd update to 4.2.20-T23 but that doesn't seem to work for me. Download the updated, uploaded it to the readynas, applied it...
emerson8
Hi,, wasn't thing about this as a beta post,,, but off course it should have been..,, sorry..
Trying frontview from different PC's = same result.
Yes, enablerootssh was installed, but won't let me in now.
So,, seems like somethings gone wrong with the fw update.
Frontview and data still ok otherwise which is GR8,
but, reboot = no, ssh = no, logs = no, so somethings not 100% ....
Might be os re-install needed or maybe reverting to T19 update ?
Thanks !
Thanks !
