jc2010
Feb 18, 2018Aspirant
Can't Write to Shares
I have a ReadyNAS 314 running firmware v6.9.2. Lately I have been unable to write to any of the shares; according to the settings, all folders appear to be read/write on the admin page, but whenever ...
- Feb 19, 2018
jc2010 wrote:
There's got to be a better/less painful way to change a system error?I don't think there's a better way to fix the filesystem corruption, though there could be a less painful way.
Another option is to use paid netgear support at my.netgear.com. They will charge of course.
mdgm-ntgr
Feb 18, 2018NETGEAR Employee Retired
Your logs show that your data volume is being forced read-only
Feb 18 18:53:30 Aboud_ReadyNAS kernel: BTRFS: error (device md127) in __btrfs_free_extent:6995: errno=-2 No such entry Feb 18 18:53:30 Aboud_ReadyNAS kernel: BTRFS info (device md127): forced readonly
Is your backup up to date?
jc2010
Yes, everything is backed up. How/why is it being forced to read-only?
- mdgm-ntgrFeb 18, 2018NETGEAR Employee Retired
That would require a more in-depth analysis. I'm not sure.
- jc2010Feb 19, 2018AspirantOk, fair enough. How do I fix it?
- StephenBFeb 19, 2018Guru - Experienced User
jc2010 wrote:
Ok, fair enough. How do I fix it?Probably your best option is to back up the data, do a factory reset, rebuild the NAS and restore the data from your backup.
That is time-consuming, but is free and is sure to result in an uncorrupted file system.
