mbr99
Feb 12, 2013Aspirant
Capacity / Expansion 3200
Hi there, I could not exactly find the answer in this forum so hopefully somebody can give me advise. We have a 3200 ready NAS. In the NAS there where 6 drives of 1 TB. The total capacity was (g...
mdgm-ntgr
Feb 12, 2013NETGEAR Employee Retired
mbr99 wrote: I don't know when a factory reset has taken place so I guess never (needed). I asume doing this will result in loosing data and all settings?
Yes.
mbr99 wrote:
So imagen I perform the reboot, and do not see any differences, i need to perform a reset?
If you need to do a factory reset it would say that expansion failed. If nothing happens after rebooting a few times you should contact support. There may be a setting you need to change (e.g. disable disk spin-down) so that expansion can take place or some other issue they need to look at.
