mbr99
Feb 12, 2013Aspirant
Capacity / Expansion 3200
Hi there, I could not exactly find the answer in this forum so hopefully somebody can give me advise. We have a 3200 ready NAS. In the NAS there where 6 drives of 1 TB. The total capacity was (g...
mbr99
Performed a reboot. No changes is the result. The following can be found in the Expension log file:
[2013/02/12 13:18:18 2265] X_level: 6
[2013/02/12 13:18:18 2265] MD degraded 0, bg_job 0, boot 1
[2013/02/12 13:18:18 2265] Read 1957072 byte from configuration
[2013/02/12 13:18:18 2265] Disk configuration matching with online configuration.
[2013/02/12 13:18:18 2265] /dev/sdb used/total/partitioned = 976759997/976762584/976759997, 60000000
[2013/02/12 13:18:18 2265] /dev/sda used/total/partitioned = 976759997/976762584/976759997, 60000000
[2013/02/12 13:18:18 2265] /dev/sdc used/total/partitioned = 976759997/976762584/976759997, 60000000
[2013/02/12 13:18:18 2265] /dev/sdd used/total/partitioned = 976759997/976762584/976759997, 60000000
[2013/02/12 13:18:18 2265] /dev/sde used/total/partitioned = 976759997/976762584/976759997, 60000000
[2013/02/12 13:18:18 2265] /dev/sdf used/total/partitioned = 976759997/976762584/976759997, 60000000
[2013/02/12 13:18:18 2265] /dev/sdg used/total/partitioned = 976759997/1953514584/976759997, 60000000
[2013/02/12 13:18:18 2265] Checking: want expand from /dev/sdg 976759997, already in use /dev/sdb 976759997
[2013/02/12 13:18:18 2265] Checking: want expand from /dev/sdg 976759997, already in use /dev/sda 976759997
[2013/02/12 13:18:18 2265] Checking: want expand from /dev/sdg 976759997, already in use /dev/sdc 976759997
[2013/02/12 13:18:18 2265] Checking: want expand from /dev/sdg 976759997, already in use /dev/sdd 976759997
[2013/02/12 13:18:18 2265] Checking: want expand from /dev/sdg 976759997, already in use /dev/sde 976759997
[2013/02/12 13:18:18 2265] Checking: want expand from /dev/sdg 976759997, already in use /dev/sdf 976759997
[2013/02/12 13:18:18 2265] Checking: want expand from /dev/sdg 976759997, already in use /dev/sdg 976759997
[2013/02/12 13:18:18 2265] Checking: want expand from /dev/sdg 976759997, already in use /dev/sdh 976759997
[2013/02/12 13:18:18 2265] Checking: want expand from /dev/sdg 976759997, already in use /dev/sdi 976759997
[2013/02/12 13:18:18 2265] exec command: Selected: 6 total=1953514584 used/resv=976759997/60000000 free=976754587, cl_at=0, property4k=1
[2013/02/12 13:18:18 2265] Not enough disk for a new array, drives with free space: 3, X_level:6
[2013/02/12 13:18:18 2265] STAGE_WIPE: Clean my_pid 2265
