Retired_Member
Jul 24, 2011(Case Solved) Nightmarish Ultra 6 4.2.18 update aftermath
CASE CLOSED : Apparently a user folder ended up in the OS folder and filled it up, probably a case of PEBCAK on my part which coincided with the update. Owner of a ReadyNAS Ultra 6 for 9 months ...
PapaBear1
Jul 24, 2011Apprentice
You other problem is that the HD154UI is not an approved drive on any ReadyNAS.
You could try to download 4.2.18 onto a PC and then try a local upgrade if you can get to Frontview.
