Retired_Member
Jul 24, 2011(Case Solved) Nightmarish Ultra 6 4.2.18 update aftermath
CASE CLOSED : Apparently a user folder ended up in the OS folder and filled it up, probably a case of PEBCAK on my part which coincided with the update. Owner of a ReadyNAS Ultra 6 for 9 months ...
Retired_Member
Jul 24, 2011Thanks for the suggestion, I completely forgot to start by that; concerning the drives, when I chose them, while they were not approved at the time, there was no indication of incompatibility, since they worked flawlessly for 9 month I doubt they chose to raise hell at the same time I updated the firmware.
Turns out the result of trying to load the 4.2.18 image is the same as with 4.2.17, "not valid for this architecture"...
So no luck...
So no luck...
