Retired_Member
Jul 24, 2011(Case Solved) Nightmarish Ultra 6 4.2.18 update aftermath
CASE CLOSED : Apparently a user folder ended up in the OS folder and filled it up, probably a case of PEBCAK on my part which coincided with the update. Owner of a ReadyNAS Ultra 6 for 9 months ...
dbott67
Jul 24, 2011Guide
My advice would be to contact support and see what they can do for you.
Of course, if you're like me, you like to try to figure things out for yourself. It's possible that one of your drives is flaky and is what's causing the trouble. You may want to do the following to help isolate and/or eliminate the source of the trouble:
1. Download the logs from Frontview and take a look to see if there's anything of consequence.
2. Test your disks using vendor tools: http://home.bott.ca/webserver/?p=388
3. Test your RAM using the Boot Menu: http://home.bott.ca/webserver/?p=252
