Retired_Member
Jul 24, 2011(Case Solved) Nightmarish Ultra 6 4.2.18 update aftermath
CASE CLOSED : Apparently a user folder ended up in the OS folder and filled it up, probably a case of PEBCAK on my part which coincided with the update. Owner of a ReadyNAS Ultra 6 for 9 months ...
Retired_Member
Jul 24, 2011So...
RAM checked out fine again...
Disks checked out fine again...
Some symptoms start appearing only after trying to change parameters in Frontview, those conditionnal symptoms include the FUBARd fan and temp monitoring and the share disappearance, other symptoms are from boot or delayed without user interaction.
Now to the OS reinstall...
