Anonymous
Jul 24, 2011(Case Solved) Nightmarish Ultra 6 4.2.18 update aftermath
CASE CLOSED : Apparently a user folder ended up in the OS folder and filled it up, probably a case of PEBCAK on my part which coincided with the update. Owner of a ReadyNAS Ultra 6 for 9 months ...
Anonymous
Jul 24, 2011And, it's exactly the same after an OS reinstall...
P.S. :
Using a whole new array of disk gets me a working system, so far.
Getting back to factory default with the new array then trying to use the problematic one doesn't solve the problems.
All hardware, FS and root system checks on the drives are OK, yet it appears the trouble is related to this particular array of drives since 4.2.18.
Guess I'll have to see with support what can be done.
P.S. :
