Retired_Member
Jul 24, 2011(Case Solved) Nightmarish Ultra 6 4.2.18 update aftermath
CASE CLOSED : Apparently a user folder ended up in the OS folder and filled it up, probably a case of PEBCAK on my part which coincided with the update. Owner of a ReadyNAS Ultra 6 for 9 months ...
dbott67
Jul 25, 2011Guide
Sounds like the upgrade went FUBAR. I'm reasonably certain that support can remote in and fix things up for you. You'll need to open a ticket and ask for L3 support and put your unit in Tech Support (Telnet-mode) when requested.
You may also want to post your support ticket number here in the event that a Jedi feels a disturbance in the force.
