jeang
Jan 06, 2009Aspirant
Changing from X-RAID to FLEX-RAID
I bougth a Readynas duo with a 1TB drive. I now bought a second 1TB drive and would like to install it and obtain 2TB capacity. I dont understand how to change the RAID settings of the unit. I have RA...
Hager
You'll have to do factory reset. Which will delete all you're current data and settings on the Duo and during a 10 minute window after you perform the factory reset you can use RAIDar to select Flex-RAID and RAID 0. So you'll probably want to backup your data before you do a factory reset or you'll lose your data.
Good Luck.
Brad
Good Luck.
Brad
