jeang
Jan 06, 2009Aspirant
Changing from X-RAID to FLEX-RAID
I bougth a Readynas duo with a 1TB drive. I now bought a second 1TB drive and would like to install it and obtain 2TB capacity. I dont understand how to change the RAID settings of the unit. I have RA...
molises
Jul 02, 2009Aspirant
I have a RND2000 with 2 disks (1.5tb seagate anda WD 1tb disk) create a separate RAID 0 volume on each disk (1.5tb disk c: and 1tb Disk D:) but the 1tb disk was not mine so i changed it for mine 1tb Samsung.... ) but the sistem only creates the unit as c: so i cant acces the 1.5tb (wich was c: previosly).
Ive tried to leave the 1.5tb unit on it own but now when i access the disk the Folder i created (GRANDE is the name) does not give me access if i dont write the login and pass that he askess wich i never included
Can i recover this unit? i mean can i read the folder by any means?
The info on the panel says that im using 75% on the space wich is true but i can see the files
Can you help me? thanx
