Jobber72
Jun 01, 2013Aspirant
Changing MTU hangs RN104
Hi, I have a ReadyNAS 104 (and an older ReadyNAS Duo V1) and I wanted to change the MTU on the RN104 so it is the same as the rest of my network; 7936. However, every time I try to change the MTU on ...
Jobber72
Jul 11, 2013Aspirant
what driver should be updated then? And do you have a fixed IP address on your unit? Both "res" and myself are on 6.0.8. and have fixed ip-addresses and both encounter the same problem. And if it is "incompatibilty" why on earth does the unit than lose its ipadres when trying to change the mtu? Does not really make sense.
