Jobber72
Jun 01, 2013Aspirant
Changing MTU hangs RN104
Hi, I have a ReadyNAS 104 (and an older ReadyNAS Duo V1) and I wanted to change the MTU on the RN104 so it is the same as the rest of my network; 7936. However, every time I try to change the MTU on ...
Feb 02, 2014Guru - Experienced User
What switch/router are you using?
marcusp wrote: Same problem here with a RN102 (latest firmware), when I set the MTU to 9000, I lost the connection, raidar does not see it and it's impossible to shut it down !
You can do an OS reinstall, which should reset the network settings (including changing over to DHCP), and will also reset the admin password back to "password".
