GAPP
Apr 21, 2013Aspirant
Changing SSL certificate
Hello, So today I found out how annoying it is not to setup your NAS on a static ip. Alot of my programs and stuff was not configured correctly, because it had changed IP. Anyways, I've changed it ...
Apr 22, 2013Guru - Experienced User
I've played with it a bit, but with Chrome all that happens is that you trade one security exception message for a different one.
GAPP wrote: Yeah, i manually installed the SSL certificate into my browser, but you are right, they should just remove it, since it's pretty useless anyways. I just thought it was really annoying to look at. :)
