stats2909
Dec 28, 2017Aspirant
GS728TP Installing SSL Certificates
Hi,
So I've got a GS728TP and I use pfsense... so far so good.
I've got my Root CA and Intermediate CA all set up and issuing certificates for servers of various types, but netgear always seems to have oddities in the devices which make life hard!
So, I've generated a p12 file, a privatekey.key file and a certificate.crt file. I've also managed to create an rsa private key file.
but in the GS728TP you require a certificate, rsa private key and an RSA PUBLIC KEY..... its this last one thats doing it!
No where else ever needs this and I'm at a loss as to how to generate it from what I've got!
Can anyone help, I'm not sure I've much hair left to pull outon this one!
Thanks
PS running software 6.0.1.18
Finally got it working.... search the pfsense forums if you want the answer!
- stats2909Aspirant
OK - I've got the rsa public key using: openssl rsa -in /tmp/switch.key -RSAPublicKey_out
but now i get an 'inconsistent value" error?! whats going one?!?
This is stupidly complex compared to everywhere else!
- stats2909Aspirant
- JohnC_VNETGEAR Employee Retired
Hi stats2909,
Welcome to our community!
Thank you for sharing the answer. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
