sander11's avatar
sander11
Clean firmware and 1&2TB -> 3TB questions
I got stuck between the hare of the changing drive models and turtle of the HCL updating so instead of moving to Hitachi 2TBs, I'm going to the 3TB model mentioned in Papa Bear's excellent thread viewtopic.php?f=24&t=53935.
My questions are:
Can I somehow align the sectors to 4k without erasing the array? I think the array was started under 4.2.5.
Is there a way to "clean" the firmware from all the custom mods I've added, without a complete factory reset? I've added vmware as well as python and bunch of other changes I don't want to affect anything going forward. I'd like to get the setup as close to factory as possible, but I don't want risk damaging /c/
TIA
  • Before you install the 3TB drives, you need to update to 4.2.17. The Beta of 4.2.19 is out, but I would hold off unless you need some of it's features. Once you have upgraded to 4.2.17 you will be on GPID rather then MBR formatting and I don't think the 4K sectors are a problem as the conversion process may take care of it. You can then add the 3TB drives one a time. You do not need to go through all the in between versions, unless you just really need to burn some time. My one NVX was originally on 4.2.9 and the other I think was 4.2.11. I upgraded both to 4.2.12 and then to use the 3TB drives I upgraded again to 4.2.17.
    I have had no problems with a mix of 3TB advanced format drives and 1TB traditional drives. (I did lose another 1TB, but that one was on my NV+).
    I once had a fellow who worked for me in accounting when I was in Virginia. He always said when making big changes it best to wear a belt and suspenders. I kind of like that philosophy. If you have data that could be put at risk if something goes wrong with the upgrade and expansion, it would be prudent to update your current and complete backup. (Or at least the backup of critical and important files). I did one of my NVX units and then two weeks later the second, and I started with the backup unit first.
  • Thanks for the clarification on the expansion. And after reading the guide, I am weighing a factory reset, although it would involve a lot of disk juggling.
    How about clearing the firmware thought? Specifically I installed vmware, which I use in .15, but isn't compatible going forward. I'm afraid it could cause a crash during an upgrade, and I know for a fact that it survives os reinstall, so would I have to manually remove it?
ProSupport for Business
