jhannah
Jul 29, 2011Aspirant
Cleaning off old time machine shares
Hi! Thanks everyone on this great forum -- today I was able to upgrade to beta firmware, get Lion to work, run migration assistant via time machine, etc -- all stuff I could only do with this forum. ...
mdgm-ntgr
Aug 08, 2011NETGEAR Employee Retired
Whilst SSH is fastest the next quickest would probably be to mount the share using CIFS, but then use the Terminal to do the deleting changing the work directory to /Volumes/c/.timemachine and delete it that way.
The advantage of SSH is that the deletions are done directly on the NAS but it does require that you know what you're doing when you use the command line. Also note that if problems are caused through use of SSH access support may be denied or a fee charged to attempt to resolve a problem.
