disconect
Oct 30, 2011Aspirant
Cloud backup over Https/webdav...
Hello, I looking for a backup via https (WebDav French Cloud Service) on Netgear NAS DUO but there is only rsync/ftp/nfs/http ...but no https ... So after read a looooot of technical documentations, ...
disconect
So, after a day of test - with fiber optic (100 Mo / 50 Mo - Theoric data download/upload)
- rsync manually on the nas of 750 mo = 1h30 hour
- backup jobs (local share to davfs mount via rsync) with frontview of 750 Mo and with enable compression and co = 2h30 hour
- backup job (local share to davfs mount NOT VIA RSYNC) = 1H30
- copy command under Midnight Commander = about 1h30 hour
and
- directly upload from a WinXP computer to the Cloud (without NAS) of 350 Mo = 5-10 min
So I got a real problem with the performance , for example, now i run a incremental backup (diff 4.4 Gb) and with "top" commande I can see that the load is extremely high :
Even before the install, I got bad perf (squeezebox server slow...), is it normal that the CPU Charge slow down the upload ?
or I should change some conf in the davfs2.conf ?
(or I should buy a new Netgear product with more mem & cpu ... :roll: )
and
top - 09:41:50 up 2 days, 16:56, 1 user, load average: 3.22, 3.82, 3.46
Tasks: 84 total, 5 running, 79 sleeping, 0 stopped, 0 zombie
Cpu(s): 19.6% us, 8.0% sy, 8.9% ni, 62.4% id, 0.2% wa, 0.2% hi, 0.6% si
Mem: 226256k total, 215744k used, 10512k free, 10384k buffers
Swap: 255968k total, 1952k used, 254016k free, 44416k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
6173 davfs2 25 0 20432 10m 2672 R 80.1 4.9 716:33.28 mount.davfs
22615 root 16 0 2976 1552 1216 R 10.4 0.7 0:00.16 top
17498 root 36 19 49568 34m 2032 R 7.0 15.7 12:50.13 minidlna
1 root 15 0 2000 880 768 S 0.0 0.4 0:06.94 init
2 root 34 19 0 0 0 S 0.0 0.0 0:00.07 ksoftirqd/0
