fdullemond
Apr 24, 2012Aspirant
Compile minidlna on debian, run on nas : libavutil conflict
Guys, I have decided to try and create a development environment for the readynas (x86) to see if I can get extend the current minidlna implementation and run it on the readynas directly. Open ...
LrdShaper
You can:
1) Make a softlink of libavutil.so.49 to /usr/lib/i686/cmov/libavutil.so.50.15.1 and make sure your LD_LIBRARY_PATH is set to /usr/lib/i686/cmov/ and try again and hope for the best
or
2) Do a static build of minidlna so you don't have shared library dependencies on the target system:
2.1) Install the dev counterparts of the libriaries required by minidlna so that you have the headers ( .h ) and static versions of the libraries (i.e. the static library of libavutil would be in libavutil-dev)
2.2) In the minidlna's Makefile, there should be a couple or so lines that are for static linking (try a search), uncomment those
or
3) Since you're on X86, just download the minidlna static binaries available from their site and save yourself the trouble
http://sourceforge.net/projects/minidlna/files/minidlna/1.0.24/
Cheers!
or
or
Cheers!
