fdullemond
Apr 24, 2012Aspirant
Compile minidlna on debian, run on nas : libavutil conflict
Guys, I have decided to try and create a development environment for the readynas (x86) to see if I can get extend the current minidlna implementation and run it on the readynas directly. Open ...
fdullemond
Hi LrdShaper,
Thanks for the suggestions, however
>1) Make a softlink of libavutil.so.49 to /usr/lib/i686/cmov/libavutil.so.50.15.1
Tried this, its nagging about incompatible version...
>2) Do a static build of minidlna so you don't have shared library dependencies on the target system:
>2.1) Install the dev counterparts of the libriaries required by minidlna so that you
>have the headers ( .h ) and static versions of the libraries (i.e. the static library of libavutil would be in libavutil-dev)
>2.2) In the minidlna's Makefile, there should be a couple or so lines that are for static linking (try a search), uncomment those
Tried this. I am getting linkage failures, so i stopped trying :-)
>3) Since you're on X86, just download the minidlna static binaries available from their site and save yourself the trouble
Yes, that would save me the trouble, but it would not give me the additional features I am seeking....
Fred
Fred
