Timdave25
Apr 03, 2015Aspirant
Complete data loss on Duo v2, Raid-X after single HDD fail
Hello, I have a ReadyNAS Duo v2 which is now just over 3 years old. I'm pretty sure it was set-up using RAID-X or RAID-1 with 2x 1TB drives providing me with 1Tb of available space. As the start of ...
Apr 03, 2015Guru - Experienced User
Just to prevent confusion - you actually have a duo v1 (duo v2 runs 5.x.x firmware, not 4.1.x). The labels are confusing, read this post for a fuller explanation: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
I think your best option is to contact support (though they will charge for data recovery). That would be via support.netgear.com.
