PeteMoran's avatar
Jul 21, 2015
Compression effectiveness?
We use a RN104 (which replaced a standalone companion PC) to save Windows Image backups and database file dumps before transfer offsite.
The Windows system images were quite compressible using NTFS compression.
The database file dumps were highly compressible.
For example;
A 333,520,896 byte file gives the following results;
NTFS 126,586,880
ZIP 57,962,496
BZ2 48,298,874
As near as I can tell, unless there is another method of checking (used 'ls -l' from ssh), the ReadyNAS on-disk size is 333,170,328, barely 1% saving and hardly worth the effort.
Consequently, the client is not getting the historic file saving ability we expected.
Are our expectations too high? Firmware is 6.2.4.
ProSupport for Business
