Smaky
Jan 21, 2020Guide
Connect to a remote NUT Server (Synology NAS)
I want to configure my ReadyNAS Ultra 6 Plus upgraded to 6.10.2 so that it shutdown orderly one my UPS signals the NUT server it is connected to to do so. In my scenario I have a Synology NAS whi...
- Jan 21, 2020
nevermind I found the solution to this. I need to configure the name of the ups as it is setup on the Synology Box. In this case the name is 'ups' once I capture that on frontview and added the IP address and user/password, the ReadyNAS was able to connect to the NUT Server.
Hopefully this is useful for someone else.
Smaky
Jan 21, 2020Guide
- StephenBJan 22, 2020Guru - Experienced User
Great that you figured it out.
Though you likely have thought of this, just in case... Make sure everything on the network path between the Synology and the ReadyNAS are also protected - preferably by the same UPS, though a different UPS with a longer run time would also work. If they are both on the same switch, then protecting the switch is enough - you don't need to protect the router, as the switch should have both devices in it's switching table.
