TACHIT's avatar
TACHIT
Nighthawk AC1900 remote access doesn't connect
I have successfully set up my modem for a while now and have no issues using the Android app to manage the Router locally.  However, I recently logged into the local web interface to turn on the remote access functions of the router to manage while away.  It shows that was successful.  I screen copied the IP and port info from the web interface but it will still not communicate with the router outside of the local network.  I have tried several different browsers to access it and the Android app doesn't show any choice for remote management.  Any pointers you can offer out there?
Thanks
  • TACHIT's avatar
    TACHIT
    Jan 10, 2025
    Yep,
    Thanks for the input.  I've only had it for 3 years purchased new so... welcome to the world of technology.
  • FURRYe38's avatar
    What model modem do you have? C####
    NG has removed web page remote access from most of there products due to security concerns. Only way to access products is thru NGs mobile apps like Nighthawk or Orbi apps?
      • FURRYe38's avatar
        Nighthawk app you can access remotely with Anywhere Access for limited monitoring and changes.
    • TACHIT's avatar
      TACHIT
      I have the Nighthawk App on my phone but there is nothing there about remote access like I've found in the manual or KB search.  My app version is 2.42.1.4373
      • FURRYe38's avatar
        Under settings in the app, do you see Anywhere Access?
