TACHIT
Jan 09, 2025Aspirant
Nighthawk AC1900 remote access doesn't connect
I have successfully set up my modem for a while now and have no issues using the Android app to manage the Router locally. However, I recently logged into the local web interface to turn on the remo...
- Jan 10, 2025
Yep,
Thanks for the input. I've only had it for 3 years purchased new so... welcome to the world of technology.
TACHIT
Jan 10, 2025Aspirant
I have the Nighthawk App on my phone but there is nothing there about remote access like I've found in the manual or KB search. My app version is 2.42.1.4373
Jan 10, 2025Guru - Experienced User
Under settings in the app, do you see Anywhere Access?
- TACHITJan 10, 2025Aspirant
no
What is odd to me is my app seems to be a newer version that what is listed as the "latest" version on the NG site.
The latest version of the NETGEAR Nighthawk app for Android is 2.42.0.4260, released on October 12, 2024.my version is 2.42.1.4373 running on a Google Pixel Android
- FURRYe38Jan 10, 2025Guru - Experienced User
I see there is a released version on Dec 24th. And seems to be that same version.
Wondering if maybe NG removed support for the C series from the NH app. 🤔
The C series is of older generation and NG may be choosing not to support it in the NH app.
