TACHIT
Jan 09, 2025Aspirant
Nighthawk AC1900 remote access doesn't connect
I have successfully set up my modem for a while now and have no issues using the Android app to manage the Router locally. However, I recently logged into the local web interface to turn on the remo...
- Jan 10, 2025
Yep,
Thanks for the input. I've only had it for 3 years purchased new so... welcome to the world of technology.
Jan 10, 2025Guru - Experienced User
What model modem do you have? C####
NG has removed web page remote access from most of there products due to security concerns. Only way to access products is thru NGs mobile apps like Nighthawk or Orbi apps?
- TACHITJan 10, 2025Aspirant
C7000v2
- FURRYe38Jan 10, 2025Guru - Experienced User
Nighthawk app you can access remotely with Anywhere Access for limited monitoring and changes.
I have the Nighthawk App on my phone but there is nothing there about remote access like I've found in the manual or KB search. My app version is 2.42.1.4373
