TACHIT
Jan 09, 2025Aspirant
Nighthawk AC1900 remote access doesn't connect
I have successfully set up my modem for a while now and have no issues using the Android app to manage the Router locally. However, I recently logged into the local web interface to turn on the remo...
- Jan 10, 2025
Yep,
Thanks for the input. I've only had it for 3 years purchased new so... welcome to the world of technology.
Jan 10, 2025Guru - Experienced User
Ya once new versions are posted, old versions are not available.
If you have a PC that is online most of the time, could install something like Teamviewer or a remote desktop app and access the modems web page that way.
Maybe time to upgrade to something newer as well.
Good Luck.
