tony007
Jan 10, 2012Aspirant
Connect to frontview ?
Hi I purchased the Netgear Pro Duo 1 today with 1x1TB disk. I set up everything and its working quite nicely, but i met a problem with accessing Frontview on a secondary machine.. The NAS is o...
Jan 10, 2012Guru - Experienced User
Not sure where you got that idea about 192.168.10.1, but it is totally incorrect. You should be able to log in from either machine.
Try https://192.168.10.117/admin in your web browser. Note there will be a certificate/security issue you need to click through.
