omygitworks's avatar
omygitworks
Connecting a 2 bay use caddy to one use port on a RN 104 is this possible
Hi pretty new to this I am running a ready nas 104 with the latest software  4.wd red  2tb drives I Have a couple of western digital green drives and a 2 bay Orico drive caddy not in any raid format ...
  • Sandshark's avatar
    Sandshark
    Dec 01, 2015
    I believe you are asking about using a multi-drive USB enclosure with your ReadyNAS and that, further, you are using it in a JBOD rather than a spanned or RAID configuration (so you see each drive in the enclosure separately).  The word "caddy" is confusing some, as that's simply a mounting device, as is used to hold the drives in your NAS.
    I know that with the older model ReadyNAS devices, it was sort of hit-or-miss whether one of these would work or not.  Some brands did, others not.
ProSupport for Business
