omygitworks
Dec 01, 2015Aspirant
Connecting a 2 bay use caddy to one use port on a RN 104 is this possible
Hi pretty new to this I am running a ready nas 104 with the latest software 4.wd red 2tb drives I Have a couple of western digital green drives and a 2 bay Orico drive caddy not in any raid format ...
- Dec 01, 2015
I believe you are asking about using a multi-drive USB enclosure with your ReadyNAS and that, further, you are using it in a JBOD rather than a spanned or RAID configuration (so you see each drive in the enclosure separately). The word "caddy" is confusing some, as that's simply a mounting device, as is used to hold the drives in your NAS.
I know that with the older model ReadyNAS devices, it was sort of hit-or-miss whether one of these would work or not. Some brands did, others not.
omygitworks
Hi I think this is one of those times when it's one of those times when using text as opposed to voice I do have wd red drives in the readynas 104 it's a drive caddy with 2 usb drives I am asking about for back up purposes will the readynas find 2 drives on the same USB port not tried yet in case it causes an issue
Thank you for the quick responce to my post though
cheers
Sandshark
Dec 01, 2015Sensei
- omygitworksDec 02, 2015Aspirant
Hi Sandshark yes thats pretty much it a 2 bay hard drive enclosure its mains powered and usb 3 connectable I have a couple of spare drives lying not being used I suspect the best thing is to just try them out on the NAS and see if it works but thanks for the assistance folks pretty quick and helpfull looks to be a great community here
