rudeen
Aug 04, 2021Aspirant
Connecting Readynas Duo RND 2150 to router
Hello Team Please I have the Readynas Duo RND2150 v2 but some members have let me know its actually version 1.Please I am trying to connect to my home router D-Link dwr-921E router .Router IP ...
rudeen
Hi Stephen
well its my first time connecting the readynas via a router.I have been able to access it via a web browser UI or via windows explorer and also Raidar.Please tell me.are all the settings ok.what could be wrong with my configuration.Because when I disconnect and then set my pc LAN IP to 192.168.1.XX I am able to reach the readynas.
Aug 05, 2021Guru - Experienced User
What address is the router assigning to your PC?
Have you tried just setting the NAS to use DHCP instead of assigning it a static IP address?
- rudeenAug 27, 2021Aspirant
Have not tried that yet.I was hoping to use a static IP since my router or network runs on a static IP but not DHCP.
- StephenBAug 27, 2021Guru - Experienced User
Are you saying that the router doesn't support dhcp?
The goal here is to re-establish connectivity, then you can change the NAS IP configuration any way you want.
