astro76's avatar
astro76
Connecting via run command
NAS 422 Firmware 6.9.2 Windows 10 Can anyoen please direct me on how to access my ReadyNAS using the run command? I want to beable to access it with out having to install a program. On the same n...
  • Sandshark's avatar
    Sandshark
    Mar 08, 2018
    If the name of your ReadyNAS is "ReadyNAS", you can type \\ReadyNAS in the run box and it will open a Windows Explorer instance with the NAS shares in it.  NOTE:  Backslashes, not forward.  You can do the same using it's IP address instead of its name.
ProSupport for Business
