GCSelvam's avatar
GCSelvam
Follower
Apr 07, 2025
Context: shares_panel_volume
Dear Team,
i am using Netgear nas 528X , suddenly I am unable to update anything in Readynas web console.
Kindly check the issues given below and give a solution.
  • 2025-04-07 15:24:05: tracker-miner-f[4847]: segfault at 200000018 ip 00007f1072bc10e8 sp 00007fff6ccf0750 error 4 in libtracker-miner-1.0.so.0.1203.0[7f1072ba3000+32000]
Selvam K.
  • I suggest downloading the full log zip and looking for errors in the zip.
    If you don't have an up-to-date backup, then I suggest doing that.  If you don't have enough disk space, then start by backing up any irreplaceable content (personal docs, photos, etc) that is only on the NAS.
  • StephenB's avatar
    • StephenB's avatar
      It looks like the big problem is that both of your volumes are full:
      /dev/md127       46T   45T  1.3T  98% /GCDBACKUPSERVER
      /dev/md126       11T   11T  414G  97% /GCDDATABACKUP
      BTRFS doesn't handle free space exhaustion very well, and my normal recommendation is to maintain at least 15% free space.  You have much less than that.
      You can try offloading data, and then try running a balance from the volume settings wheel.  Maybe do that with the smaller volume first.  It likely will take a while, since you've never run a balance on the either volume.  The balance will consolidate free space, making it more useful to the file system.
      If that is successful, you'll need to expand the volumes before you add more files to the NAS.
ProSupport for Business
