LodyJ
Aug 05, 2015Aspirant
Convert ReadyNAS Duo v2 to JBOD
Hi, I've got this old ReadyNAS Duo v2 with two 1TB harddisks which is running X-RAID. My system has changed and I don't need RAID anymore. Question : Is there any way, to convert the X-Raid optio...
- Aug 10, 2015
Sorry mdgm,...
I totally overlooked the fact, that the last suggestions came from you.... apologies for that...
As I have stated before... I'm really getting old.... grin...
Anyway I am equally grateful for your help on this.!!
Very best regards,
Lody J. Claessen
Aug 09, 2015Guru - Experienced User
LodyJ wrote:
It appeared, that, although the label said it was a v2 unit, I have a version1.
So... things changed completely...
Well, not really. The basic situation is unchanged. With either unit you need to back up your data and do a factory reset to switch to jbod.
Download the 4.3.8 RAIDar (PC version is here: http://www.downloads.netgear.com/files/ReadyNAS/RAIDar_Win_4_3_8.exe)
Then back up the data, and document the configuration of the NAS (including any add-ons).
Remove one disk from the duo, then initiate the factory reset procedure. You can do this from the web ui (click system, then update, then click on the factory default tab). Or you can do that using the procedure in the hardware manual (page 15-16): http://www.readynas.com/download/documentation/HM/Duov1_NV%2Bv1_HW_en_06Dec11.pdf
Using the web ui is easier.
Once you begin you have a short window to get the Duo to use flexraid.(~page 19 here: http://www.downloads.netgear.com/files/GDC/RND2110/RAIDiator4-1_SW_en_06Dec11.pdf). You do this by launching RAIDar, and choosing setup. The select flexraid / raid-0.
The NAS will complete the factory install. Then hot-insert the second disk, and create the second jbod volume.
Then complete the NAS configuration, set up the shares, and restore the data from backup.
LodyJ
Aug 09, 2015Aspirant
Hi StephenB,
Thanks for your reply.
The procedure I mentioned in my previous message didn't quite work out.
- I did manage a manual factory reset
- I did get de "settings-dialog" in my RAIDar window.
- I did set it to Flexraid0
- But in the end, the unit still ran RAID1 on two disks.... so... no result.
Your procedure looks good, but.....
The link http://www.downloads.netgear.com/files/ReadyNAS/RAIDar_Win_4_3_8.exe) returns a "404-not found".
Have been looking around, but couldn't find it.... but..... I already installed RAIDar 6.0 for windows...
Do you think version 6.0 will do the same trick..???
Cheers,
Lody J. Claessen
- StephenBAug 09, 2015Guru - Experienced User
Well, if you got it into flexraid, then the RAIDar you are using is ok.
I am thinking you left both disks in the duo. I said to remove one.
Try again I guess.
- mdgm-ntgrAug 09, 2015NETGEAR Employee Retired
If it is in Flex-RAID you should be able to go to Volumes, delete the existing volume and then create the ones you want.
If it is still in X-RAID and it doesn't work using RAIDar 6.0 when you try again, then you will need to try RAIDar 4.3.8The URL you tried for 4.3.8 has a ")" (no quotes) at the end that shouldn't be in it. If you remove the ")" you should find the URL works.
- LodyJAug 10, 2015Aspirant
Hi StephenB,
You were totally right.!!
I hadn't seen the "one disc" condition and....
...I didn't spot that parentheses at the end of the URL...
Well... that's old age (67) I presume..
I did as you instructed and yesssss..... it's working OK now ...
I'm really, really grateful, that you stuck with me on this.!!
Very, very best regards,
Lody J. Claessen
