LodyJ
Aug 05, 2015Aspirant
Convert ReadyNAS Duo v2 to JBOD
Hi, I've got this old ReadyNAS Duo v2 with two 1TB harddisks which is running X-RAID. My system has changed and I don't need RAID anymore. Question : Is there any way, to convert the X-Raid optio...
- Aug 10, 2015
Sorry mdgm,...
I totally overlooked the fact, that the last suggestions came from you.... apologies for that...
As I have stated before... I'm really getting old.... grin...
Anyway I am equally grateful for your help on this.!!
Very best regards,
Lody J. Claessen
mdgm-ntgr
Aug 10, 2015NETGEAR Employee Retired
If it is in Flex-RAID you should be able to go to Volumes, delete the existing volume and then create the ones you want.
If it is still in X-RAID and it doesn't work using RAIDar 6.0 when you try again, then you will need to try RAIDar 4.3.8
The URL you tried for 4.3.8 has a ")" (no quotes) at the end that shouldn't be in it. If you remove the ")" you should find the URL works.
LodyJ
Aug 10, 2015Aspirant
Hi StephenB,
You were totally right.!!
I hadn't seen the "one disc" condition and....
...I didn't spot that parentheses at the end of the URL...
Well... that's old age (67) I presume..
I did as you instructed and yesssss..... it's working OK now ...
I'm really, really grateful, that you stuck with me on this.!!
Very, very best regards,
Lody J. Claessen
