LodyJ
Aug 05, 2015Aspirant
Convert ReadyNAS Duo v2 to JBOD
Hi, I've got this old ReadyNAS Duo v2 with two 1TB harddisks which is running X-RAID. My system has changed and I don't need RAID anymore. Question : Is there any way, to convert the X-Raid optio...
- Aug 10, 2015
Sorry mdgm,...
I totally overlooked the fact, that the last suggestions came from you.... apologies for that...
As I have stated before... I'm really getting old.... grin...
Anyway I am equally grateful for your help on this.!!
Very best regards,
Lody J. Claessen
Aug 10, 2015Guru - Experienced User
mdgm wrote:
The URL you tried for 4.3.8 has a ")" (no quotes) at the end that shouldn't be in it. If you remove the ")" you should find the URL works.
:manfrustrated: Sorry about the ). I'm still getting used to Lithium.
FWIW Netgear should still publish the 4.3.8 RAIDar download links here: http://kb.netgear.com/app/answers/detail/a_id/20684/~/readynas-downloads
There are some issues with RAIDar 6 and the older legacy NAS.
LodyJ
Aug 10, 2015Aspirant
Sorry mdgm,...
Very best regards,
Lody J. Claessen
