CougarFan
Oct 31, 2015Aspirant
Copying from ReadyNAS Duo slows to a crawl
For years when I have tried to copy files to/from my ReadyNAS Duo, it has been an excruciating experience--very slow. After a computer restart or at unexplained times, speeds seem to be OK, but most...
Oct 31, 2015Guru - Experienced User
If the PC is windows, please try NasTester, and report the speed it gives (http://www.808.dk/?code-csharp-nas-performance)
CougarFan
Nov 03, 2015Aspirant
I ran NasTester and got these results:
NAS performance tester 1.7 http://www.808.dk/?nastester
Running warmup...
Running a 400MB file write on Y: 5 times...
Iteration 1: 11.25 MB/sec
Iteration 2: 10.56 MB/sec
Iteration 3: 11.25 MB/sec
Iteration 4: 11.25 MB/sec
Iteration 5: 11.25 MB/sec
Average (W): 11.11 MB/sec
Running a 400MB file read on Y: 5 times...
Running warmup...
However, I normally get much slower times, and the more I copy/paste files, the worse it gets. In fact, I tried copying all the files (about a third of a Terabyte) to my computer (because I'm trying to back them up to a USB 1 Terabyte drive), and after 12 hours, copying had basically stopped. Also, just now, after I completed the test above, when I opened Windows Explorer and clicked on the Y drive (a shared folder in the drive), it hung. The Windows Vista spinning circle just keeps spinning, and Windows Explorer has the message "Not Responding." It did this for two minutes before finally showing me the contents.
I restarted the computer and then did three large copies from the ReadyNAS Duo to my computer. Note that both the ReadyNAS Duo and my computer are connected to my router with Ethernet cables. These are the copies and the speeds:
1. 739 items (519 MB): Started at over 5 MB/sec and ended around 4.35 MB/sec
2. 25,494 items (50.5 GB): Started at around 3.5 MB/sec and ended around 7.79 MB/sec
3. 11,763 items (11.8 GB): Started at around 7 MB/sec; however,
Items remaining (after about 16 hours): 395 (465 MB)
Speed: 192 KB/sec and falling
So I finally quit. While I sometimes can copy and paste a few files without problems, it's just as likely to take a long time to transfer files. It has been this way from multiple computers.
Any ideas?
- StephenBNov 03, 2015Guru - Experienced User
11 MB/sec sounds like there is a fast ethernet link on the path.
Are the PC and the NAS both running gigabit?
