wolffpower
Mar 09, 2020Aspirant
Copying from ReadyNAS to USB
Hello: I'm trying to copy a large file from my ReadyNAS RN314 to a USB3.0. I want to copy the file directly to the USB, not via my laptop, since that's painfully slow. I'm running Windows 10. I'v...
Marc_V
Mar 09, 2020NETGEAR Employee Retired
Welcome to the Community!
Have you checked the logs why the copying of file stopped? Have you tried reformatting the USB drive on the NAS? It would be best if you can check on the logs or check if there were any errors showing up after it stopped copying the data.
Have you tried drag and drop? IMO, copying it thru your Computer is the easiest way but if your USB drive is already connected on the NAS there shouldn't be a problem with that. You may want to try reinserting the USB Drive on the NAS do the copy again.
HTH
Regards
- wolffpowerMar 09, 2020Aspirant
Hi Marc_V and thanks for the quick response.
1. I have checked the logs and there is nothing to indicate that the copying started, or stopped, for that matter.
2. I have tried drag and drop from within Windows Explorer (is that what you meant?) but that is very slow: NAS > wireless > LAPTOP > wireless > USB... I would have hoped that with the USB plugged directly into the NAS, I could copy directly.
3. I formatted the USB in the NAS as FAT32. No change.
