wolffpower
Mar 09, 2020Aspirant
Copying from ReadyNAS to USB
Hello: I'm trying to copy a large file from my ReadyNAS RN314 to a USB3.0. I want to copy the file directly to the USB, not via my laptop, since that's painfully slow. I'm running Windows 10. I'v...
schumaku
Mar 09, 2020Guru - Experienced User
wolffpower wrote:I'm trying to copy a large file from my ReadyNAS RN314 to a USB3.0. I want to copy the file directly to the USB, not via my laptop, since that's painfully slow. I'm running Windows 10.
SAMBA does support all the various features allowing different methods for supporting Server-Side Copy To my knowledge, everything is configured and enabled on recent ReadyNAS systems.
One point is not clear: Windows 10 does - unless it was hevaily modded form the default - not allow different access to the same storage/server using different credentials resp. authenticated and nonauthenticated access. If using the comon trick to access the NAS once by using the hostname, like \\radynas\share and by IP like \\192.168.123.45\USB , Windows 10 does take this as two different devices and won't request any server side function - the data _will_ transfer over the network twice.
The correct approach would be granting group or user based access to the USB storage, and access both the internal storge share and the USB share using the same name and security environment.
But also when using the Web based UI to access the share: The copy process will be local, and it must succeed.
wolffpower
Thanks schumaku . Yes, I had assumed it would work with the NAS web-based UI, else why allow the "copy" and "paste" options within the UI in the first place? Very strange!
JFYI: I had enabled anonymous access on the USB based on other discussions I had read, but it doesn't appear to have made any difference.
Any further suggetions?
- schumakuMar 09, 2020Guru - Experienced User
Ahhhh this was added on top of the standard access rights - OK.
Not much to add - you might try to run a file system check on the USB device, e.g. for NTFS on a Windows system. While the non-Linux-native driver are very robust when it comes to most access right issues (bypassing almost everything known on NTFS) they can struggle if the file system isn't healthy.
