wolffpower
Mar 09, 2020Aspirant
Copying from ReadyNAS to USB
Hello: I'm trying to copy a large file from my ReadyNAS RN314 to a USB3.0. I want to copy the file directly to the USB, not via my laptop, since that's painfully slow. I'm running Windows 10. I'v...
wolffpower
Thanks schumaku . Yes, I had assumed it would work with the NAS web-based UI, else why allow the "copy" and "paste" options within the UI in the first place? Very strange!
JFYI: I had enabled anonymous access on the USB based on other discussions I had read, but it doesn't appear to have made any difference.
Any further suggetions?
schumaku
Mar 09, 2020Guru - Experienced User
Ahhhh this was added on top of the standard access rights - OK.
Not much to add - you might try to run a file system check on the USB device, e.g. for NTFS on a Windows system. While the non-Linux-native driver are very robust when it comes to most access right issues (bypassing almost everything known on NTFS) they can struggle if the file system isn't healthy.
