wolffpower
Mar 09, 2020Aspirant
Copying from ReadyNAS to USB
Hello: I'm trying to copy a large file from my ReadyNAS RN314 to a USB3.0. I want to copy the file directly to the USB, not via my laptop, since that's painfully slow. I'm running Windows 10. I'v...
schumaku
Mar 09, 2020Guru - Experienced User
wolffpower wrote:I'm trying to copy a large file from my ReadyNAS RN314 to a USB3.0. I want to copy the file directly to the USB, not via my laptop, since that's painfully slow. I'm running Windows 10.
SAMBA does support all the various features allowing different methods for supporting Server-Side Copy To my knowledge, everything is configured and enabled on recent ReadyNAS systems.
One point is not clear: Windows 10 does - unless it was hevaily modded form the default - not allow different access to the same storage/server using different credentials resp. authenticated and nonauthenticated access. If using the comon trick to access the NAS once by using the hostname, like \\radynas\share and by IP like \\192.168.123.45\USB , Windows 10 does take this as two different devices and won't request any server side function - the data _will_ transfer over the network twice.
The correct approach would be granting group or user based access to the USB storage, and access both the internal storge share and the USB share using the same name and security environment.
But also when using the Web based UI to access the share: The copy process will be local, and it must succeed.
Marc_V
Mar 09, 2020NETGEAR Employee Retired
I agree with schumaku, checking the USB drive is best to make sure that the cause of the issue is not the USB itself.
Have you tried using another USB to check if it has the same issue?
- StephenBMar 09, 2020Guru - Experienced User
Note you can do a direct copy on the NAS to the USB device using a backup job. And of course it is easily done with ssh.
