wolffpower
Mar 09, 2020Aspirant
Copying from ReadyNAS to USB
Hello: I'm trying to copy a large file from my ReadyNAS RN314 to a USB3.0. I want to copy the file directly to the USB, not via my laptop, since that's painfully slow. I'm running Windows 10. I'v...
Marc_V
Mar 09, 2020NETGEAR Employee Retired
I agree with schumaku, checking the USB drive is best to make sure that the cause of the issue is not the USB itself.
Have you tried using another USB to check if it has the same issue?
Mar 09, 2020Guru - Experienced User
Note you can do a direct copy on the NAS to the USB device using a backup job. And of course it is easily done with ssh.
